If you are looking for the best way to convert MBOX files to CSV format, I recommend using the BLR MBOX Converter tool. It provides a simple and reliable way to export MBOX emails into CSV files while maintaining important email details like sender, receiver, subject, date, and message content.
Steps:-
Steps:-
- Download and install the MBOX Converter tool.
- Add the required MBOX file or folder.
- Preview mailbox data before conversion.
- Select CSV as the export format.
- Choose the destination location and start the conversion process.
