What Happens When AI Controls Your Data Center’s Power and Cooling Systems
$828.9USD
Have you ever considered what it might mean for AI to manage your data center's power and cooling? Imagine, instead of workers constantly monitoring the temperature and power, you have AI doing it automatically. It controls everything at the optimal time, keeps things cold, and saves energy.
This is not some distant dream, either. Algorithms are actively implemented by companies like Google and Microsoft to make managing their power and cooling systems more efficient, resulting in reduced utility bills, less waste, and improved performance.
What AI is Doing to Manage Power​
Sure, so what does this mean, AI is doing? AI acts as a super intelligent energy manager that is always 'on':
• Power utilized in servers and cooling elements
• Temperature and airflow in the data center
• Server load that drives heat generation
• Power pricing and the ability to delay operation or consume when the costs are higher
It then makes adjustments to cooling, moves workloads, or waits to run certain tasks for the most optimal cost to operate. In essence, it is providing balance and control.
The best part is that AI learns from everything it sees, and over time gets better at predicting whether your datacenter needs something done before a problem arises.
More Efficient Cooling, Less Anxiety​
Cooling a datacenter is constantly cumbersome. Too much cooling increases power consumption, while too little cooling causes overheating. Again, AI in this scenario does more than just monitor – it predicts what’s going to happen.
It monitors outside temperature, humidity, and workload and modifies cooling before the system even needs it. For instance, if forecasted to be a hot day, AI will increase cooling hours before you have a chance to notice.
Here’s how it helps:
  • Takes fan and chiller speed adjustments automatically
  • Sensors let you know constantly with updated temperature changes
  • It can predict predictions to avoid overheating before it occurs
You couldn't do all of that by hand, you would require a team!
Why It Matters​
AI-based power and cooling reduce costs for companies, improving energy savings of up to 30%. This is a lot when your data center is running all day, every day.
It lowers the environmental impact too — less energy, means less pollution, and smaller carbon footprints. You save money and help the planet — it’s a win-win.
Can AI Be Trusted?​
I personally say yes 100%. While it feels strange to let a computer manage your cooling system, when you see how much money and time you save, you will enjoy it more than ever.
AI doesn’t replace humans; it just enables us to work more efficiently by taking away the use of human resources to deal with the boring bits.
