VPS Memory Profiling Made Easy: Find and Fix Leaks Fast
$1,016.2USD
I often run apps on my VPS, and nothing is more upsetting than watching the memory go up for no reason. What about you? Have you ever watched your RAM rise even after you didn't have any more users visiting your website? You think, "What the heck?" I know I've thought that before I learned to perform memory profiling and leak detection.
What Memory Profiling Tells You​
The first time I used a memory profiler, I felt like I finally got a full look inside my app. I kept asking myself, "Why is my app consuming so much memory?"
So here is what memory profiling tells you:
  • How much RAM your app is actually using
  • Which functions or parts are continuing to grow
  • Where the leaks are starting
When you discover a leak, it is like discovering a hole in a bucket. After you plug it, everything works much better. And it feels fantastic.
The Issues With Memory Leaks in a VPS​
Because a VPS comes enabled with a limited memory situation, it only takes a slight leak to be in trouble. I have seen apps crash because one worker just held on to the memory forever. Have you seen your VPS slow down like it is half-asleep? If so, there was probably a memory leak.
Common Memory Leakers​
  • Database connections that you forgot to close
  • Cache items that never cleared
  • Background tasks that loop forever
  • Bugs in third-party libraries
I once had a memory leak in a Node.js app because I forgot to return once in an async loop. I mean, just one missing return and a headache for the leak.
Simple Tools You Can Use​
There is not need for expensive tools. The following simple tools can be used quite effectively on a VPS.
For Node.js
  • clinic.js
  • Chrome DevTools heap profiler
For Python
  • -tracemalloc
  • -objgraph
  • -memory_profiler
For PHP
  • -Xdebug
  • -Blackfire
For System Memory
  • -htop
  • -ps_mem
  • -valgrind
How I Find a Leak​
A simple process:
  • Load the app
  • Watch the memory
  • Watch for it to keep increasing
  • Review the heap snapshots
  • Address the problem
  • Test again
Nothing too fancy, but it works.
Memory profiling is a big concept, but memory profiling tools let you let your VPS run faster and smoother. It helps organizations save money, reduce crashes, and peace of mind. If you feel your VPS should run fast for “no reason,” just know there is a memory profiling reason. You just haven't looked.
Start profiling and find the leak and fix it. Your VPS will feel new again.
