Struggling with managed or unmanaged VPS? Confused me too when I set up my first site. Fortunately, there was someone on Reddit who guided me through.
I will try to describe it in as simple a manner as possible so that you can decide for yourself what suits best for you.
Reddit Tip: Use managed VPS if you want your site to function at all times.
Why Some People Like It
Reddit recommends: Don't do unmanaged unless you're comfortable with server issues or are willing to learn incrementally.
I began with managed VPS and later moved to unmanaged—after I messed up a couple of times and learned the hard way.
Begin slow. Go managed first. Learn the rest later.
And if you ever get stuck, Reddit is always there to ask.
What Is a Managed VPS?
A managed VPS is comparable to purchasing take-out and having it delivered—the business does all the work for you. Reddit users suggest this is best for novices.Why It's Great for New Users
- Help is never far away – Someone will come and repair it if something occurs wrong.
- Automatic updates – Nothing to install.
- Cute as a button to use – You receive a straightforward control panel to handle everything.
What Is an Unmanaged VPS?
Unmanaged VPS provides you with complete control. You do it all yourself. Sounds like a blast, but it ain't fun.Why Some People Like It
- Is cheaper
- Greater control – You can do anything.
- Better performance per buck
What Does Reddit Recommend for Newbies?
The majority of Reddit users suggest go for managed VPS if:- You don't know anything at all about servers yet.
- You don't want to spend hours in fixes.
- You'd prefer your site to work without problems.
- Want less stress? Go managed and enjoy.
Last Thought
Ask yourself: Do I want to learn server things now, or do I just want my site to work?I began with managed VPS and later moved to unmanaged—after I messed up a couple of times and learned the hard way.
