Top VPS Operating Systems in 2025: What Web Hosting Experts Recommend
$85.3USD
Struggling to pick the right operating system for your VPS? Don't worry, you're not alone. I've tried servers myself for years, some installs went smoothly, other well, not so smoothly. What operating system for VPS you choose does make a difference if you don't want unwelcome server visits in the dead of night.
So, what are hosting gurus using in 2025? Let's take it apart—the simple way.
Ubuntu – The Default for Most Individuals​
  • Ubuntu is the darling of beginners and pros alike.
  • Latest LTS versions (like 24.04) are stable and polished.
  • There’s a guide for almost everything online.
It plays nicely with tools like Docker, Apache, NGINX, MySQL, and more.
Honestly, it’s my personal go-to. Why? Because when things go wrong, it’s easier to fix. Plus, I’ve never had Ubuntu randomly break on me. That alone saves hours.
AlmaLinux – Reliable and Red Hat-Compatible​
Remember when CentOS shifted direction and left us all scratching our heads? Well, AlmaLinux is here to the rescue.
  • Free and built to mirror Red Hat Enterprise Linux.
  • Ideal for use with cPanel, Plesk, or other control panels.
  • Super solid. Fantastic for long-term projects.
I have used it on client servers and it has run perfectly.
Debian – Clean and Lightweight​
Some people want control and no fluff at all. That is Debian.
  • Runs fast and stays stable.
  • Updates are slow and careful, which helps avoid nasty surprises.
If you are very good with Linux then you should use Debian otherwise avoid it. Because it’s not flashy but it gets the job done.
Rocky Linux – Alma’s Quiet Twin​
Rocky Linux is another great choice. It’s a bit like AlmaLinux, just with a different team behind it.
  • Also built to be RHEL-compatible.
  • Has a growing fanbase and good updates.
Some of us will still like it better than Alma. Honestly, try them both and decide which feels more comfortable to you.
There's no one-size-fits-all solution here:
  • Want it easy? Use Ubuntu.
  • Need RHEL-level stability? Try Alma or Rocky.
  • Want complete control? Debian's your friend.
So, please choose what feels comfortable and what you can actually handle if something goes wrong. Because when your site crashes at midnight, you are the tech only support. Also, let me know if there is any other you are using.
