Simplify Cloud Management with Infrastructure as Code (IaC) and Terraform
$960.4USD
Have you ever spent an hour clicking through your cloud account to get everything in order, only to realize you forgot to change one small setting? I have too—more than once! That’s why Infrastructure as Code (IaC) is an absolute life-changer. Instead of manually putting everything together, you can write a piece of code that automatically sets up your cloud. It’s straightforward, replicable, and without human errors. It’s great, right?
What is Infrastructure as Code (IaC)?​
You can think about IaC as building your cloud the same way you would build a program. Instead of manually setting up servers and networks, you simply describe what you would like in small coded files.
You would have something like this:
"Create 3 servers, 1 database, 1 load balancer."
The tool reads your file and does the work for you in a matter of a few minutes—exactly the same each time.
It’s like saving your ideal cloud and calling upon it again and again.
Why Terraform Is So Popular​
Several Infrastructure as Code (IaC) solutions exist: AWS CloudFormation, Ansible, etc. However, Terraform is arguably the best. Why? Terraform works in any cloud; AWS, Azure, Google Cloud, you name it.
So, here’s why people love Terraform (myself included):
  • Easy language: Terraform is written in a clear and readable way called HCL.
  • Code reuse: You can repurpose the same template over and over for different execution projects.
  • Preview prior to change: Terraform issues a 'plan' which shows what it will change before it actually does to prevent surprises.
  • Versioning: You can save your Terraform files in Git, so if something breaks, you can revert to the previous state quickly.
Wouldn't it be nice if every mistake could be undone in one command? Terraform can do just that.
Reasons Why You Will Enjoy IaC​
Cloud setups can get messy quickly. You begin with one server, then you add load balancers, security groups, and storage in to mix. Doing this manually can be a complete pain.
With IaC, you can:
  • Automate everything from start to finish.
  • Ensure every setup is identical (no more "it worked on my machine").
  • Save time (no more 3 a.m. debugging to fix things).
And every person on your team will be able to collaborate on the same setup just like normal coding.
Final Thought: Take Back Your Cloud​
If you want your cloud setup to be quick, simple, and reliable then Infrastructure as Code is necessary. Tools like Terraform will not only save you time, they will increase your system reliability.
The next time you launch your cloud console, consider: wouldn’t it be awesome to do all of this using one file? That’s the magic of Terraform.
Once you use it, you will look back on how you used to setup things old school.
