SharedGrid.com Hosting Review
$29.3USD
SharedGrid is really shaking things up in the web hosting world by mixing quality with friendly prices. Whether you’re just trying to maintain a little blog or you’re running some massive enterprise, this platform is totally here to cater to your every whim. They focus on design, which supposedly makes your experience better. You’ll see, they’ve put thought into every detail to make sure it works well. Their big selling points are reliability and security. A jaw-dropping 99.99% uptime, supported by a robust Service Level Agreement, means you can forget about sudden downtimes. They also monitor everything. And their fancy self-healing technology ensures your services run smoothly. Security measures follow CIS guidelines closely. Docker containerization steps in to isolate each process, establishing another shield of protection. This system functions like an impenetrable fortress, safeguarding your data while allowing you to concentrate on your grander ambitions.
Our Detailed SharedGrid Review
Services Offered by SharedGrid
Cloud Web Hosting
SharedGrid, offering a whole smorgasbord of Cloud Web Hosting plans to meet your every whim! Every plan has pretty much the same core features, like unlimited bandwidth, databases, and built-in DDoS protection. They back up your data every 12 hours. Plus, they keep those backups safe for 14 days. To top it all off, they’ve got Litespeed Web Server and LSCache to speed up loading times. Their Enhance Control Panel makes management so easy, even if you’re a total beginner.
  • Lite Plan
The Lite Plan targets individuals and small projects looking for budget-friendly hosting. For just £1.99 each month, you can host two websites. It comes loaded with 10 GB of NVMe storage. One CPU and one GB of memory support your projects. You also get 25 processes per website.
  • Advanced Plan
The Advanced Plan costs £5.49 each month. This plan is perfect for your growing websites. You can host five websites with it and 30 GB of NVMe storage at your fingertips. Each website gets one CPU, ensuring decent performance. With two GB of memory, it handles tasks easily. Every website can run 50 processes simultaneously. Redis Cache boosts speed, so your sites load quicker. You also have the option to create manual backups whenever you want.
  • Premium Plan
The Premium Plan fits businesses demanding more from their hosting solutions. At £9.99 each month, you can manage 10 websites easily. You’ll enjoy 60 GB of NVMe storage along with two CPUs. Two GB of memory are also included, ensuring better performance and each website can run 75 processes. Redis Cache and manual backups are part of the deal, just like in the Advanced Plan.
Cloud Reseller Hosting
SharedGrid's Cloud Reseller Hosting suits entrepreneurs who want to offer white-label hosting. Each plan gives you unlimited bandwidth, allowing your business to grow without restrictions. Essentially, you hold the keys to a hosting empire, all while avoiding the usual infrastructure stress. Control panels allow you to customize easily, so you can brand your services with your own name. Private nameservers let your clients see only your brand, not SharedGrid’s. Focusing on growth becomes possible because every feature works in harmony while SharedGrid manages the technical details for you.
  • Starter Plan
The Starter Plan is for those who want to kick things off online. At £14.99 monthly, it supports up to 10 websites. Enjoy 50 GB of NVMe storage to store your data. One CPU powers your operations, keeping everything running smoothly. With one GB of memory, you manage tasks efficiently. Each website can handle 25 processes, which gives you flexibility.
  • Business Plan
For £28.99 per month, you get the Business Plan. This plan allows hosting 20 websites. Enjoy 100 GB of NVMe storage for all your data needs. Each website has two CPUs for smooth performance. You also receive one GB of memory per website. Redis Cache speeds up your sites, making them run faster. Creating manual backups is another handy feature included in the package.
  • Enterprise Plan
The Enterprise Plan caters to resellers who require high-quality hosting. Priced at £41.99 per month, it supports up to 30 websites. You obtain 150 GB of NVMe storage, which gives ample space for all your projects. Included are two CPUs, ensuring stable and reliable performance for your needs. Memory capacity stands at 2 GB, allowing you to multitask without issues. Redis Cache enhances your performance, and manual backup options add a layer of safety. Also included is a bonus Blesta license with a value of £7.50 per month, adding even more value to the package.
Cloud Dedicated Hosting
Cloud Dedicated Hosting serves as your answer if you seek exclusive server resources. This option provides excellent control and performance, ensuring everything runs without hiccups. They even generously include dedicated IPs, enhancing the stability and reliability of your server. Your server remains secure with cPGuard, which protects against various threats. Critical fixes are applied effortlessly with rebootless kernel updates, so you won’t experience any service downtime. Depending on what you need, you can select from Apache, NGINX, or OpenLiteSpeed web servers. Two main plans await your choice: the basic and premium options. A Silver Plan is priced at £27.99 per month, while you can opt for the Gold Plan at £45.99 per month, both fitting neatly between the basic and premium tiers.
  • Bronze Plan
The Bronze Plan is perfect for those wanting to step up their hosting game. This plan comes at a price of £22.99 per month and allows you to manage up to 10 websites. With 80 GB of NVMe storage, you have sufficient space to grow as your projects develop. Two vCPUs take care of your workloads, ensuring everything runs smoothly. Memory is allocated at 4 GB, giving you the ability to manage tasks without stress. You also receive 2,000 GB of bandwidth, which is ample for handling traffic without running into limits.
  • Platinum Plan
The Platinum Plan comes in at £80.99 per month. This option supports hosting for 25 websites, offering ample space to manage several projects. With 500 GB of NVMe storage, data storage becomes a trivial concern. Eight vCPUs provide the processing power needed for demanding tasks. Memory reaches 32 GB, which helps ensure that operations across all sites run without interruptions. With 10,000 GB of bandwidth, you can handle plenty of traffic. If you want to add extra websites, it costs £.20 each, following the same structure as the Bronze Plan.
Other Services
SharedGrid provides Virtual Private Servers, often referred to as VPS, to fulfill your hosting needs. If you prefer, Managed VPS Hosting is available, allowing you to select what suits your specific situation best. Designed to adjust as your projects evolve, their solutions save you from facing unnecessary difficulties. Exploring these services allows you to discover the one that aligns with your requirements. Making choices is straightforward, as they cater to various technical preferences without adding extra complexity.
Why Choose SharedGrid?
SharedGrid really knows how to stand out from the crowd with their clear approach. Unlike those other hosting options that rely on fancy CDNs like CloudFlare to make their test sites look good. It seems impressive at first until you realize it's all just an illusion. But not here! Nope, at SharedGrid, you get actual server performance, no misleading third-party enhancements trying to steal the spotlight. Free CloudFlare integration is offered, but that’s not the main focus. Instead, they concentrate on displaying real server capabilities to foster trust. Plus, their servers are conveniently located in the UK and the USA, which gives you the flexibility to choose a service location that meets your needs. And if you’re curious about how well they perform? Just try testing WordPress installations.
Pros
  1. SharedGrid provides pricing that keeps hosting within reach for many users.
  2. You’ll appreciate the 99.99% uptime guarantee, which promises consistent service. With self-healing technologies, it keeps your performance stable, which is quite handy.
  3. Following CIS guidelines shows a commitment to security, while Docker containerization helps protect your data.
  4. True server performance shines through here, without any gimmicks for speed.
  1. Right now, SharedGrid offers only two server locations. This might not be enough for a global audience.
  2. Some features, such as extra websites in Cloud Dedicated Hosting, cost extra. Don’t be surprised when adding more hits your wallet.
SharedGrid really stands out as the web hosting choice of the century that balances reliability, security, and affordability. Transparency and performance take priority, helping to meet various user needs without creating unnecessary complications. It almost feels like they designed their services with real user insight. They proudly offer a buffet of plans and features to cover every possible hosting need you can imagine. Their services cater to everyone, from individuals who maybe just want to share cat photos, to businesses that think they’re the next big thing. So, rest assured, your hosting requirements will totally be met without any hiccups.
