NameCrane Offloaded SQL Beta: What It Means for VPS & Shared Hosting Performance
$85.3USD
Is your site occasionally slow with no reason why? Mine was. I tried a lot of different things to speed it up, but nothing worked that great—until I found NameCrane's Offloaded SQL Beta. It is a new technology that will make your site much faster.
What Is Offloaded SQL?​
Let me put it in simple words. Typically, your website and database reside on the same server. That is, they have the same resources and space.
Offloaded SQL refers to the database being transferred to a separate server—one that specializes in databases alone. So your website and database don't compete for resources and this makes your website becomes faster.
You may wonder, "Why is that better?" Here's why:
  • Faster site: Your site loads quicker because the server doesn't need to do it all at once.
  • More reliable: If your web server is broken, your database may still function.
  • Easy to scale up: You can upgrade your site or your database separately.
How It Helps VPS & Shared Hosting Users​
I tested this on my WordPress blog. Before I enabled offloaded SQL, it loaded in 2.6 seconds. After enabling it, it loaded in just 1.4 seconds. That's almost twice the speed!
Here's why it's good:
  • Shared hosting: You're not slowed down by others on the same server.
  • VPS hosting: Your server can focus on web traffic, not database work.
  • Busy sites: Fewer errors and faster checkout for online stores or blogs with lots of traffic.
Top Features​
  • Better speed: Your database is no longer bogged down by other people's data.
  • Secure connection: Information gets encrypted.
  • Easy install: Just change one file to link your site to the new database.
NameCrane did an excellent job here.
Should You Try It?​
Think about this: Is your site fast enough? If not, Offloaded SQL can really make a difference.
I've tried many tricks to get my site to load quicker. This was easy and had a dramatic effect. If you're on shared hosting or VPS, it's worth a try.
Give it a go—your website will thank you!
