Gongora
Newbie
In order to package files, we use the following command:
Tar -cvf file.tar / dir / a / compress /
[align=justify]In order to untar the .tar files, we use the following command:
Tar -xvf file.tar
[align=justify]If you want to see the contents of a .tar file, the following command is used:
Tar -tf file.tar
[align=justify]
To compress files in .gz format, the following command is used:
Gzip -9 file
[align=justify]To decompress .gz files, the following command will be used:
Gzip -d file.gz
[align=justify]
To compress files in bz2 format, the following command is used:
Bzip file
To decompress .bz2 files, use the following command:
Bzip2 -d file.bz2
-d: indicates decompression.
Note:
To compress files in tar.gz format, the following command is used:
Tar -czfv file.tar.gz files
[align=justify]To decompress files with tar.gz extension, use the following command:
Tar -xzvf file.tar.gz
[align=justify]In order to see the contents of a compressed file in tar.gz, the following command is used:
Tar -tzf file.tar.gz
[align=justify]
To decompress tar.bz2 files, the following command is used:
And to see the contents of a tar.bz2 file, use the following command:
In order to compress in zip format, the following command will be used:
Zip file.zip files to compress
In order to unzip the zip files, the following command is used:
Unzip archive.zip
To see the contents of a zip file, put the following command:
Unzip -v zip.zip
Rar files
To compress in rar format, the following command will be used:
Rar -a file.rar files
To decompress files in rar format, the following command is used:
Unrar -x file.rar
To view the contents of a rar file, use the following command:
Unrar -v file.rar
Unrar -l file.rar
