Have you ever gazed around your home and wondered, "Everything is smart these days; even my fridge is smart!" I have thought that many times. Smart devices can bring joy to our daily lives, and at the same time, they can be problematic if you don't adequately protect your devices. Let's discuss some ways to protect your IoT devices reliably while making your life easy.
IoT security protects:
Hackers have an affinity for IoT devices that normally have:
1. Ensure Your Passwords Are Strong
One of the easiest safety measures against hackers is to ensure your passwords are strong.
2. Always Keep Your Devices Updated
Updates are designed to fix security issues. Don't ignore them. Update your devices.
3. Use a Dedicated Wi-Fi Network For IoT Devices
I use "guest Wi-Fi" only for my IoT devices. That way, if I get hacked, the devices stay constrained to the guest network. You may want to do this as well.
4. Set Up Two-Factor Authentication (2FA)
Many devices offer two-factor authentication. If you can enable it, do so. It strengthens the security of the devices and/or the apps that access your devices.
Why IoT Security Matters
Many years ago, I bought a cheap smart lightbulb. It would work, but it would act funky and disconnect. I remember thinking, "If someone can hack a lightbulb, then what about a smart oven or smart water heater?"IoT security protects:
- Devices in smart homes
- Devices in medical applications
- Connected vehicles
- Devices in manufacturing
How Hackers Get Into IoT Devices
Common VulnerabilitiesHackers have an affinity for IoT devices that normally have:
- A vulnerability because soft or default credentials are used
- Outdated operating-stystem, firmware, or application updates
- No or limited encryption support
- Open ports or misconfigured settings
Simple Ways to Improve the Security of Your IoT Devices
You don't need to be in the tech sector to use these simple tips that will help tighten the security of your IoT device.1. Ensure Your Passwords Are Strong
You Might Even Consider Some Additional Tools
If you want to enhance safety you may even consider:- Firewalls
- App to monitor your devices
- Routers with security features
