Unsure whether a hybrid cloud or VPS solution would work better for your needs? I totally get it! I required high speeds, maximum security, and full control over my system, while spending as little money as possible. I discovered that combining Hybrid Cloud and VPS provided me with just what I needed, and so far it has been very successful for me!
What I Like About Using Hybrid Cloud and VPS:
Things I always perform:
Optimizing Security
Security is paramount, so I ensure that my VPS is protected before using the hybrid cloud as an overflow.
Selecting the Correct Configuration
This is an effective method for scaling safely and quickly, especially if you have ever attempted to grow an application without a plan!
Why Combining Hybrid Cloud and VPS Works for Me
With this setup I can utilize both the Hybrid Cloud and a VPS server. The Hybrid Cloud allows me to have access to additional computing power from the cloud (when needed). On the other hand, I am using my VPS for handling sensitive information and having total control over my data. By separating the workloads between these two types of servers I am able to optimize each server's resource allocation, thus improving performance overall.What I Like About Using Hybrid Cloud and VPS:
- Higher performance through dedicated VPS resources
- Lower cost due to ability to scale up on demand
- Improved security of sensitive data
How to Achieve Improved Speed Performance
Speed is everything! I always ensure to host my VPS server in the closest geographical location to the Cloud Data Centre. Have you had a bad experience with an application being extremely slow due to it being hosted so far from the server?Things I always perform:
- Utilize Load Balancers to manage traffic
- Cache to the VPS
- Monitor CPU/RAM Daily
Optimizing Security
Why Risk Compromising Data?
Basic considerations for securing my VPS:- Firewall and private network(s) enabled
- Use of encrypted connections
- Least-Privilege access control
