How VPS Hosting and Hypervisors Work Together
$810.0USD
Have you ever thought about how a VPS (Virtual Private Server) can feel like your own computer even though it is on the same physical server with other VPSs? It sounds impressive and makes it seem magical, but what actually makes this happen is Hypervisor — the software that enables VPS hosting. Let me break it down simply.
What Is a Hypervisor Going to Do?
The hypervisor is a software based in between the real hardware (CPU, memory, storage as an example) and all the virtual servers that running on it. You can think of it as a smart assignment as to what VPS gets what pieces of hardware at any moment in time.
There are two primary sorts of hypervisors:
Type 1 (Bare-Metal): Runs immediately on the server hardware. Examples: VMware ESXi, Microsoft Hyper-V, KVM. These are extremely fast and used by the majority of hosting companies.
Type 2 (Hosted): Runs within another operating system. Examples: VirtualBox, VMware Workstation. These are well suited for home and testing environments.
Most VPS providers leverage Type 1 hypervisors due to their speed, reliability, performance, and overall security.
How the Hypervisor Shares Resources​
You’re probably wondering, how can one machine run multiple VPS servers at once? The trick is resource management.
The hypervisor divides up the following resources:
CPU – Each VPS receives a portion of the strength of the main processor.
Memory (RAM) – Each VPS is allotted a set amount of memory.
Storage space – Each VPS is given a portion of the primary disk.
If one VPS attempts to exhaust more than its share of resources the hypervisor will throttle that VPS and make sure that all other VPS servers on that machine can continue to operate correctly. Your server will remain stable throughout, even if there is a rogue VPS on the server.
Why This Is Important To You​
So what's the big deal about the hypervisor? The hypervisor is what determines how well your VPS performs — your site's speed, uptime, and reliability depend on it.
A good hypervisor offers:
Strong isolation – Other users can't affect your VPS.
Better performance – You always get your fair share of resources user.
Easy upgrades – You can upgrade to more RAM or CPU at any time.
This is why VPS hosting is the perfect balance between cheap shared hosting and expensive dedicated servers.
Think of the hypervisor as a music conductor, that allows all of the virtual servers to work together perfectly. Each VPS is simply playing it's own tune, and they don't interfere with each other.
So, next time you restart your VPS or install something new, you now know the smart system behind the scenes — the hypervisor is quietly doing all the hard work for you! Pretty cool, right?
