How to Verify WHMCS Licenses
benclark
Newbie
$8.0USD
WHMCS is a common billing and automation platform used by web hosting companies to manage the common tasks like billing clients, creating hosting accounts, and handling domains.WHMCS requires a valid license registered to your domain.WHMCS licenses are different types, such as monthly or owned licenses. Licenses are issued directly by WHMCS, and by third party sellers as well.
Why do you need to Verify WHMCS License?​
Verifying the license helps you to check that you are using an official licensed copy of WHMCS. Using an unverified or null license can cause serious issues such as Security
Risks, Malware, Server Downtime, Legal Consequences and No Updates or Support From WHMCS. WHMCS regularly checks for license authenticity, and to disabled invalid copies.
Using the WHMCS License Verification Tool​
WHMCS provides their official online tool to check the license status of connected domains.
Follow these steps to use it:​
  1. Visit the License Verification page. Open the WHMCS website and go to the WHMCS License Verification Tool.
  2. Enter your WHMCS domain in the tool form, type the domain name where WHMCS is installed, if WHMCS is active at billing.example.com/index.php , then you need to type billing.example.com. Only enter the main domain name.
  3. Submit and after a min (depend on your internet connection) check the result. The tool will display if the domain is authorized. If the license is valid for that domain, you will see a confirmation message and if not, you’ll see an “unauthorized” message. But If your license is valid and it still shows as unauthorized, try clearing WHMCS cache or refreshing the page and make sure the domain you're checking matches the one registered on your license.
This tool is the official way to confirm if your domain is valid to run WHMCS. It shows clearly whether the domain is listed on the license.
How to Check License Status in WHMCS Admin​
You can also verify the license your WHMCS installation from the admin dashboard:
  • Log in to the WHMCS admin. Open the WHMCS admin dashboard usually at billing.example.com/admin .
  • Open License Information and click on the help menu (and choose License
  • Information. This page shows you the current details of your license, including the license key, type, and the domains.
  • Test server connection to the WHMCS licensing server. On the License Information page, click on Force License Update to re-verify the license with WHMCS. This validates WHMCS connecting the license server and updates the status.
  • The License Information page in the admin dashboard is the most easy way to see if your license is updated. If the domain is not listed or the license has expired, it will be indicated there.
By following these methods, you can check whether your WHMCS license is valid or not.
