How to Install and Set Up VPS Hosting for Trading Bots: Easy Guide for Traders
Are you ready to run trading bots without worrying that your laptop will crash, or that your internet’ll go offline? I’ve been there too, and the best answer is a VPS (Virtual Private Server). VPS’ are always online, and when you set-up your bots on it, the VPS will keep it running without you.
VPS for Trading Bots​
The one thing I can say about trying to run trading bots from your home computer, is that it’s not the best way to ensure stability when using trading bots. What if the power goes out, or? What if you lose your internet connection? Your bot is no longer trading and you are now at risk of losing money, due to the fact that you are not allowing the bot to manage your trades.
A VPS offers:​
  • Always online – Your bots could run 24/7.
  • Fast speed – Fast connections with brokers and exchanges
  • Anywhere access – Log in on any device
  • Easy upgrades - If your bots develop, you can add more power.
Step 1: Choose a Good VPS Provider​
Don’t just go with the lowest cost. Look for:
  • Location close to your broker's server provides less latency.
  • At least 2 CPUs and 4 GB RAM if you want to run multiple bots.
  • Uptime SLA of 99.9% or more.
  • Responsive support staff.
I once had a fairly cheap host, and my bot froze while executing a large trade (don't judge). I learned very quickly that cheap is not worth it when it comes to good VPS.
Step 2: Choose Your Operating System.​
Most VPS hosts will allow you to choose between Windows or Linux.
  • Windows VPS – Quite simple if your bot has a small enough app or piece of software.
  • Linux VPS – Faster, cheaper, and a good alternative if you know the basics of commands.
I started with Windows due to its simplicity, but once I learned and progressed I moved to Linux for performance.
Step 3: Set Up Your Trading Bot​
Here's a simple procedure for doing so:
  • Log into your VPS (RDP for Windows, SSH for Linux).
  • Install your choice of trading platform for example: MT4, MT5, or your proprietary platform.
  • Upload your bot files.
  • Test it out once before leaving it run.
Additionally, have a backup plan—sometimes a VPS fails too.
Step 4: Securing Your VPS​
This step is critical. Always use:
  • Strong passwords.
  • Two-factor authentication if available.
  • Regular maintenance.
A small hack can ruin your hard work. Your money is at stake.
