I wonder if you, like me, have looked at your containers to later think, "They’re safe. Nothing can escape from here." I used to think the same; until I learned how a small issue with a container can lead to a major data breach. So let’s discuss this in simple, friendly language.
Once they are on the host they can access:
Weak Isolation
Some container systems don't isolate the container from the host well. When that isolation fails, the hacker can fully compromise the host.
Kernel Bugs
A bug in the kernel can allow attackers to run malicious commands as root user. I spent one whole night fixing a bug in the kernel because I was concerned that it would allow someone to break the entire system.
Privileged Containers
If you ever started a container with --privileged just so it would "work," you just opened the door to let an attacker have access to the system.
The bottom line: One misconfigured setting + one bug = the attacker owns everything.
Why Container Escapes Are Bad
I picture containers like a lunch box that has everything held inside. But what happens if someone taps the bottom? That's a container escape. Trace and exploit some kind of escape in the container to get out to the host.Once they are on the host they can access:
- Source files
- Databases
- Internal networks
- Cloud accounts
How Hackers Escape from Containers
Hackers often rely on a few common techniques:Weak Isolation
Kernel Bugs
How Escapes Result in Large Data Breaches
Because when an attacker has access to the host, they can:- Move to other hosts
- Steal database backups
- Copy secret keys
- Install malware inside of your container images
Preventing Container Escapes
These are simple steps that I follow:- Use rootless containers
- Perform kernel updates for your operating system
- Update your container runtime
- Scan images for vulnerabilities
- Don't run containers in privileged mode
- Use security tools integrated with the container system like AppArmor, SELinux, and seccomp
