Hosting Infrastructure Monitoring Made Easy with Nagios, Zabbix, and Prometheus
$800.5USD
Have you ever experienced a server crash while you were busy and discovered the server had crashed hours later? I have, and it's not cool. That's why monitoring your hosting service is so important. Monitoring tools like Nagios, Zabbix, and Prometheus are essentially a watcher on your servers, apps, and networks, so you can sleep well knowing that they are working.
Why Monitoring Is Important.​
Servers do not fix themselves. It's very easy for something small to cause your website, emails, or database to stop functioning. Monitoring tools will alert you in real time as well as provide easy-to-read reports, and you can fix problems before your customers notice. Think of monitoring tools as the security guards for your server.
Nagios: The Reliable Classic​
Nagios has been around for a long time and is very stable. You can configure it to monitor nearly everything.
  • Alerts: Allows monitoring for issues or failures, sending messages if something goes wrong.
  • Plugins: Extensions that allow monitoring of apps, servers, or network devices.
  • Dashboard: Displays the status of everything being monitored in one place.
I like Nagios for its reliability. Once you set it up, it just quietly watches over everything. But it does take some work to set up.
Zabbix: Easy to Visualize Everything​
Zabbix is a more modern tool with a clean interface. I think it suits monitoring and analyzing your servers very well.
  • Graphs: Shows server performance on charts.
  • Automatic actions: Can automatically fix or send alerts based on issues.
  • Integration: Can integrate with other products through APIs.
I've used Zabbix on medium-sized systems, and I particularly liked how easy it was to visualize which slow server was using the most CPU or memory through the dashboards.
Prometheus: The metrics-dream​
Prometheus is a developer's answer to your request for the ability to track metrics over time. You can use it very easily in conjunction with Grafana for presentation and dashboards.
  • Real-time: Efficiently collects and stores data.
  • Alertmanager: Notifies you when something is not right.
  • Cloud-centric: Designed for Cloud-centric apps and Kubernetes environments.
Overall, if you're in DevOps circles, you'll love Prometheus. Very flexible but requires some engineering/setup skills to implement and deploy fully.
Monitoring helps you avoid downtime and know your servers like the back of your hand. Set alerts, monitor your dashboards, and your servers will pretty much monitor themselves. Trust me, it makes life so easy—and your users will suffer no adverse effects.
