If you've ever used Linux or tried to install your own operating system, you've probably been exposed to GRUB2, the tiny piece of software that initiates your computer and subsequently boots up your operating system (OS). These days, we are so comfortable with boot loaders, that we can hardly think of some proverbial "bricks" around it. It's also unfortunate that there were significant security vulnerabilities found in GRUB2 that gave attackers the opportunity to compromise millions of computers.
Once I broke GRUB2 when I was playing with my Linux setup - and I spent hours trying to fix it. So, when I heard hackers could take advantage of GRUB2 itself for attacks, my first thought was, Wow, that's a disaster just waiting to happen.
Here’s the bad part:
• Who was affected? Millions of computers running Linux, servers, and even some devices like routers and IoT devices.
• What could hackers do? Access to the root of your computer (full control of your computer).
Think of it like they entered your house before you locked your doors.
How Did Hackers Use It?
The problem came from how GRUB2 loads files when it starts. There were times when it didn’t check the files properly, so the hackers were able to hide bad code inside. If the hackers were successful, they would have control of the system without the user even knowing.
So what do you do:
1. Update GRUB2 immediately: Your package manager should take care of it.
2. Enable Secure Boot: That gives you another layer of safety when it verifies what happens during the boot process.
3. Scan your boot folder: If you are concerned, check everything, and if it is unusual you will know it.
What is GRUB2, and why should I be concerned?
GRUB2 (Grand Unified Bootloader) works like the front entryway to your computer. When you push the power button, GRUB2 ultimately determines what is and isn't loaded. When you are not concerned about GRUB2 at all, usually the vulnerability has close to zero effect on your physical security and is operating as an "invisibly safe" aspect (as would a lobby attendant monitoring your approach to the front gantry of a facility while you, quite innocently, text message away). However, if GRUB2 has a vulnerability, it is like an untraceable intruder providing an opportunity for attackers to divert before your system boots up.Once I broke GRUB2 when I was playing with my Linux setup - and I spent hours trying to fix it. So, when I heard hackers could take advantage of GRUB2 itself for attacks, my first thought was, Wow, that's a disaster just waiting to happen.
Where Was the Blunder?
The researchers found GRUB2 didn't check some files properly - hackers could exploit the error and run their own bad code in the time it takes your computer to boot up. This gives them access to your system at boot time.Here’s the bad part:
How to Protect Yourself
The good news? The fixes are out. The only thing you need to do is get your system updated. If you do not do this, you are still exposed.So what do you do:
