Ftp client
Decent12
Newbie
$0.0USD
hi Which ftp client you are using and which you prefer to peoples to use i am using Winscp and i also prefer Winscp because its easy to use.
I use FileZilla. I find it very easy and fast to use. I also have WinSCP which I believe is better, but haven't really worked with it yet. It's family of PuTTY.
I really like Winscp, it works good, but I prefer the cpanel file manager if it is available. In my experience, ftp is not a good reliable option.
FileZilla for sure, it's easy to use, it is updated regularly and it integrates into explorer very well for drag and dropping, etc.
I use FileZilla whenever I need an FTP client or an FTP server for general usage.
If you're doing something like editing webpages, you may like the built-in FTP client so that you can just hit save and have it updated on your site as well. I would also encourage you to use sFTP (supported by most modern FTP clients) to ensure security when doing your file transfers.
