Best VPS Load Testing Methods in 2025 Using k6 and Locust
$1,016.2USD
I enjoy testing VPS performance, and I always try new tools to test how much traffic my server can handle. Have you ever been excited to put your server to the test without breaking anything? For example, both k6 and Locust allow you to do that. These two load-testing tools take the pain out of load testing in a fast and fun way. Let me show you how I use them, and why it matters.
Why Load Testing Matters​
Whenever I set up a new VPS, I think: "Can this thing survive real traffic?" So, I need to test it out, as I always want to see if there are any surprises before real end users click around. Load testing tells me:
  • How fast the VPS responds
  • How many users it can handle
  • Where the bottlenecks occur
  • What parts need upgrading or fixing
It feels great to know this problems before they occur. You agree?
Using k6: My Fast and Friendly Tool​
I like k6 for a number of reasons, but the biggest is that it runs super fast, and it looks very clean. I can get test results that are easy to read in just seconds. I often use the phrase, it is the "sports bike" of load testing tools.
What I like about k6:
  • Simple JavaScript makes for easy scripting
  • Very fast performance
  • Output is clear and helps eliminate issues quickly
  • Perfect for APIs
I joke that k6 is "plug-and-play," though that may be a little slangy, but you get the gist. If I want to see how an API responds to traffic, k6 is open first. You know why developers love easy tools? K6 is it.
Using Locust: The “Crowd Simulator”​
Then there's Locust, it feels like I'm sending an army of users on to my VPS. It's in Python, so the learning curve is pretty shallow for many developers. I like Locust for end-to-end user journeys. I've said and written the benefits of Locust a few times!
Why I use Locust:
  • Python-based and easy to comprehend
  • Good web UI creating a nice control of test
  • Great for big user flows
  • Good for scaling in multiple machines
k6 vs Locust: My Thoughts​
Friends will sometimes ask, "Which one is better?" I always say, it depends:
  • Use k6 if you want speed, API testing, and clean outputs.
  • Use Locust if you need complex user behavior or want the flexibility of Python.
Both tools feel robust, and I use them both together frequently. Why choose one when you can use both?
Simple Tips for Improving VPS load testing​
If you want better results, try this:
  • Start small, then ramp up the load
  • Monitor CPU, RAM, and I/O while performing the tests
  • Save the results to compare the VPS plans.
  • Repeat testing after server modifications.
Doing these things prevents me from making mistakes and also allows me to track real performance improvements.
