Best Hosting Solutions for Blockchain Applications: Secure, Fast & Scalable Options
$1,220.8USD
Did you know that the way a blockchain application functions is different from other types of applications? All of the processing that blockchain applications perform happens across many nodes, all of which are part of a distributed network. So, when you think of a blockchain application like a crypto wallet processing thousands of transactions a minute. So let’s talk about hosting solutions for blockchain applications and figure out what actually works and what doesn’t.
Why Blockchain Needs Special Hosting​
To see how a blockchain application differs from traditional website hosting, here are a few key points:
  • Performance is always high
  • Scalability (adding new nodes to increase capacity) is very quick
  • Security (protecting your information from malicious attacks) is critical
  • All blockchain applications rely on low latency to maintain a continuous connection to the network, even during heavy load periods.
If the hosting solution you choose does not have the capacity to handle the unique requirements of your business needs, then it is likely to be very expensive in the long run.
Dedicated Servers for Blockchain Apps​
When you want complete control over your blockchain applications, dedicated servers are an excellent choice. You gain access to all of the raw processing power, as well as unlimited customization options, allowing you to configure everything from CPU and RAM to network speeds.
The benefits of using dedicated servers include:
  • Maximum Performance
  • Increased Security
  • Full Root Access
  • Reliable Uptime
However, dedicated servers typically require a higher investment, and you will need to manage them yourself. If your project will likely be expanding quickly and requires serious dedication, then dedicated servers may be worth the investment.
VPS Hosting for Smaller Blockchain Projects​
For those with small, privately funded blockchain projects, VPS Hosting is the perfect solution. VPS Hosting uses a Virtual Private Server to create dedicated servers for you without the added expense of purchasing a dedicated server. VPS Hosting provides a good balance of cost and user control without the added expense.
With VPS Hosting, you get the following features:
  • Dedicated Resources
  • Scalability
  • Fast Speeds
  • Strong Isolation from Other Users
As your application grows, it is easy to upgrade from a VPS Hosting plan to a larger VPS hosting plan, allowing you to continue to grow your application as your user base grows. There is no need to worry about scaling when you have a VPS Hosting plan; simply start scaling as needed.
Flexible and Fast - Cloud Hosting​
The way cloud hosting has become possible has given the impression that it is almost like magic.
From automatic scaling to easy handling of heavy workloads with no interruptions, cloud hosting allows you to distribute your workload across many different servers.
The most important features are:
  • Automatic scaling
  • High availability
  • Networks of servers all over the world
  • Automated backup
The cloud hosting option is the best for those applications that grow and change very quickly.
Hosting Providers That Specialize in Blockchain​
A growing number of businesses are offering specialized blockchain-hosting options with all of the necessary hardware and software pre-packaged with built-in support for nodes, GPUs, etc. If you're going to launch Web3 applications, an NFT platform or if you plan to create or maintain mining nodes, these types of service providers are the best way to go.
Here are some features to search for when looking for a blockchain solution provider: GPU acceleration, DApp support, ability to host multiple nodes, and support for smart contracts.
Blockchain hosting companies understand the challenges of the technology and can save you time and frustration.
In conclusion​
The bottom line regarding your blockchain application’s hosting solution is that it should be fast, flexible and secure. It really depends on your project’s size and objectives as to which type of provider to choose from – whether you go with a VPS, dedicated server, cloud hosting or a specialized hosting service.
